850 headlight issue
wickid54
Year and Model: '95 850 GLT
Post by wickid54 »
i need your advice again.
i have a '95 850 GLT N/A.
the headlights, lowbeam only, are extremely dim.
i've read posts here where jsut new mightbulbs were the issue, but i'm not sure tbhis is my case.
when you look at the light housing, the side with the lowbeam lamp is located is not as refelctive.
can these be cleaned, do i need to replaces them, or is this normal for this weird little car?
pics below:
thanks again, guys.
ChiNorm
Post by ChiNorm »
I replace my bulbs about every three years, they do get dimmer after a while, so do this first. Lots of folks use the Silverstars, which can be purchased at any auto parts store, I use the PIAA, which I get from TireRack. They are a big improvement over stock.
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
wickid54 wrote:i need your advice again.
pics below:
thanks again, guys.
Klaus
zhenya
Year and Model: 97 855 T5,98 V70 AWD
Post by zhenya »
Two common causes of dim lights on older cars are pitting/hazing of the lenses as you've noticed, and secondly, voltage drop to the bulbs due to aging/corroding of connections. It would be interesting to check what voltage you are getting at the bulb sockets (I assume it should be about charging voltage ie. ~13.8v - someone correct me if I'm wrong). Adequate voltage is the most important part of bright lights, so this wouldn't be a bad place to start.
Otherwise, these cars see dramatic improvement by replacing the lenses with new e-code style glass, widely available from the normal parts places. These cost not too much more than a set of boutique bulbs with far greater end result. My car went from miserable lights to lights every bit as good as the HID's on my much newer Audi with just this one change.
Red-Arrow
Year and Model: 850 T5 1995
Been thanked: 2 times
Post by Red-Arrow »
I have the same problem and its your reflectors. They are faded and worn out. Sort of getting them electroplated with new silver foil just buy new ones from Ebay or some Website like FCP or Volvo parts online.
Forget about new bulbs honestly.
Life would be enjoyable if it wasn't so painful to live.
