finding new exhaust split flanges online
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
This topic is in the MVS Volvo Repair Database » Replace Thermostat Volvo 850, S70, V70, C70 or XC70
Skribb
Year and Model: 740 wagon 92
Post by Skribb »
i recently replaced the donut gasket at the cat conv and main exhaust pipe from the motor and discovered one of the flanges broke rather they are 2 piece flanges and the bottom bolt rusted to the point it broke off the flange completely during tightening the flanges from both pipes together ive check all the local part stores where i live and nobody carries them or knew what i was talking about when i said it was a 2 piece flange ive look at multiple sites online with no luck and was wondering if someone may know where to find one i have a local napa store but its currently closed so not able to find out if they can get one my only other optin at this point is cutting the flared ends of the pipes off and welding them together with a sleeve but would rather fix it right right now i wrapped it with baling wire for a temp fix.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
If you mean the flanges arrowed on the attached they are part of the pipe.
740 exhaust system.pdf
(132.39 KiB) Downloaded 282 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Solo
Year and Model: '94 945
Post by Solo »
I have this problem on my 940 and I found the proper repair parts for this here at skandix. Good luck.
Edit : Also see this
