Hello everyone!
1991 volo 740, base model, automatic, regina.
I have been reluctant to post here, because I thought I could solve my problem with the seemingly infinite resources available on this forum. Alas.
The story is, as I was driving one day, between twenty and thirty miles an hour down a residential road, my volvo stops running. Suddenly my check engine light goes on and simultaneously my car stalls. It was all I could do to get it to the side of the road before I lost momentum. No start since then. This is what I have done/replaced so far:
1. Timing belt seems ok; I can see the cam shaft spin when the ignition is turned. Also, I can fee air coming out of the tail pipe.
2. I can hear the in tank fuel pump whine as the key turns.
3. I replaced the fule pump relay.
4. The fuel pump fuse is ok.
5. I replaced the distributor cap and distributor rotor.
6. I repaced the ignition coil.
7. Prior to replacing the ignition coil thare was no spark when a spark plug was set near a grounded bolt.
7. I have about a half a tank fo gas.
8. The OBD gave me 1-1-1 on 2 and 6.
My initial thoughts were that is was the timing belt or the fuel pump. Since there was no indication of trouble before it stalled, I do not suspect the fuel pump. Since the cam shaft spins I do not believe it to be the timing belt. The only thing that could be considered a warning was that occasionally on the fisrt turn of the ignition it would not start, but on the second turn it would go. Now it will turn over, all lights come on, but it will not start. The tachometer indicates about 1000 rpms when I turn the ignition, so I do not believe it to be the rpm sensor. Any help would be greatly appreciated! Thanks a lot!
Volvo 740 no start
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
It is strange that no code was set with the check engine light on.
Regarding point 7 (the first one) - since replacing the coil have you got a spark? If not you need to be looking at the power stage.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
91volvo740
- Year and Model: 740 1991
Thanks for the reply, billofdurham.
There is still no spark, and I have already ordered a new powerstage. I will respond again when I install it. Regarding the check engine light, its occurence was simultaneous with the engine stalling, maybe that could have prevented an error from being logged, or maybe all the dash lights came on at once, and I just looked for the check engine light so that is what I saw.
91volvo740
Here is an update on my car.
I replaced the RPM sensor, and I now get a spark, but my car will still not start.
It has been sitting for about a month. Will starting fluid get my car going again, or would anyone suspect another problem, that perhaps frequently occurs in conjunction with a failing/failed RPM sensor? My car has a half a tank of gas. I am going to pick up starting fluid today, but with my luck. Thanks for any advice!
- billofdurham
If you have a spark it will start on the starting fluid. However, it may die as soon as it has burned the fluid which may indicate a fuel problem.
Bill.
Bill.
Previously:
Previously:
91volvo740
Friends, relations, whatever the hell meatwad is. My car barely started on the starting fluid and then died. The closest it came to running on its own was a heavy idle with the check engine light on. I have replaced the fuel pump relay, and the fuse for the fuel pumps is ok. Also, I can hear the in tank fuel pump when the ignition is turned. Furthermore, there was no indication prior to this fiasco that there was a fuel delivery problem, i.e. no rough idle, no lack in acceleration etc. Any suggestions as to where to begin?
As always any advice is greatly appreciated.
- billofdurham
How long since the fuel filter was changed?
Bill.
Bill.
Previously:
Previously:
91volvo740
Not since I've owned it, which is about a year. Don't know prior to that. Would a bad filter have such a sudden and permanent failure?
Retired MVS Contributor
Yes, if it has ice in it...I hear that it gets pretty cold in Minnesota...Can you hear the fuel pump run for a few seconds when the key is turned on?...91volvo740 wrote:Not since I've owned it, which is about a year. Don't know prior to that. Would a bad filter have such a sudden and permanent failure?
Jerry
91volvo740
Yeah, I can hear the fuel pump. It seems plausible that the filter is frozen, it was pretty cold out while my car was not running. Thanks for the second on that suggestion, jerrymcc, I think I will make that my next replacement.
- 753 Views
Last post by HiggsZyBigzy
- 763 Views
Last post by lummert
- 2726 Views
Last post by dorvin
- 3617 Views
- 611 Views
Last post by mrt740
