Exhaust on CONICAL FLANGE turbo ?
bugsbunnies95_850t
- Year and Model: 99 v70R
so in m research i CANNOT find an exhaust for my conical flange turbo 850 ! where can i get one or how can i change the flange so as to put one on there ?
- Year and Model: Many Volvos
- Been thanked: 75 times
Has your turbo been changed out and which flange are you talking about - the flange off of the exhaust manifold or the flange to the downpipe?
If you don't have a stock setup it might be time to put on the Nomex suit and posit the question over on Volvospeed. They will incinerate you but you might actually get an answer if it is an aftermarket setup.
bugsbunnies95_850t
no its a stock 15g turbo.. and the turbo flange itself
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
You can change the flange to a straight one and get an aftermarket exhaust that will fit.
I assume you're wanting to start with the downpipe.
'98 S70 T5
2016 Chevy Cruze Premier
bugsbunnies95_850t
what do i have to do to change the flange ? can i just unbolt it and bolt another one on ? im sure its more complicated than that .. and yah im thinking a turbo back... but is that nessacary for 300 whp / or can i get away with a cat back ? id be running about 15 lbs of boost maybe more i gotta do researchto find out how much id need to reach that. that is running as little boost as possible to be kind to the enigne
- 742 Views
Last post by erikv11
- 285 Views
Last post by WhatAmIDoing
