I recently purchased a 2003 XC90 T6 2.9 (139k) and I believe I'm getting some pretty bad gas mileage..like 210 miles on a full tank. I recently ran some seafoam through the fuel tank, got an oil change with synthetic oil, but am still getting bad mileage.
Any suggestions?
I'm figuring it may be a good idea and cut my losses and get ride of the car.
03 X90 T6 Poor Gas Mileage (any suggestions)
JDS60R
- Been thanked: 3 times
If it were broken= yes
If inaccurate or worn out =No
( the oxy sensors very slowly loose accuracy and the computer can not differentiate between differing engine conditions and a worn sensor)
By 80-100K they are far from accurate and generally cause the car to run rich leaving deposits in the chambers which raises compression, and can cause early detonation. Then the timing backs off and the car makes less power. Without regular replacement you get worse mpg, less power and more deposits.
Replacing oxy sensors is just a part of regular maintenance. Luckily you only need to do it about every 80-100K miles.
Read up on all of the threads and you will see that direct fit Bosch sensors (for most Volvos) is the best choice.
Save lots of money by using Matt's amazon link and buying them at Amazon. I install lots of them from Amazon and have yet to have a single issue on a Bosch direct fit.
Retired
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
John is this something that one can check for by monitoring the O2 voltages via OBD? I wouldnt mind checking to see if mine are getting "tired" but I dont have money to just throw at the car(s)...
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
JDS60R
Unfortunately checking for accuracy requires a gas analyzer. By 100K its gone -it needs one. Bosch spent a fair amount of time seeing how long they could really say "their" O2 sensor lasts. They still agree by 100K on a heated sensor - its gone.
The cycle rate can be graphed but the cycle rate usually slows down long after accuracy is lost. When cycling fails early you get lots of complaints of "no power/ low power"
I like to time the O2 replacement with a new set of plugs or other maintenance. Every 100K plus used car I buy gets a new one on it as part of its journey back to stage zero. I wouldn't put it on if I could get away without it. But folks love power and mileage.
PS -proper maintenance and use of a motor oil that has minimal burn off (exposes oxygen sensor to less contamination) play an important role in extending the life of sensors
O2_TechInfo_Intervals.pdf- (493.06 KiB) Downloaded 954 times
Retired
gshadow325
- Year and Model:
since my xc90 has 150,000k miles i think i am due for a SET of three. looking at the previous owners service records it did not mention anything about a CEL for oxygen sensors. I would assume they are still oem. Although he did see 22mpg oh the highway, i confirmed it with a trip to pittsburg from philadelphia. A good 500 mile round trip. Thats because my AOC/DEM did not work. Yes it does give you better gas mileage. Now since i have fixed the dem/awd i see 200 miles per tankfull. yes that bad.
So i bought the following bosch sensors
17188 Volvo Oxygen Sensor Front Right (S80 XC90) - Bosch 17188 (1) @ $148.95 = $148.95 - 10% coupon $134.06 FCPgroton
16541 Volvo Oxygen Sensor rear (S80 XC90) - Bosch 16541 (1) @ $86.34 Amazon
17135 Volvo Oxygen Sensor Front Left (S80 XC90) - Bosch 17135 (1) @ $101.30 Amazon
Eeuroparts was $510
fcpgroton was $438.40 - 10% $394.46
so fcpgroton and amazon shipped was $321.70 just got all order confirmations 3 minutes ago
I should be installing these sometime in the next two weeks. i will report back with my findings. FYI- car currently has NO CEL's, fresh plugs, pcv serviced @135k, t/b and w/p done @ 120k, lets see.....
Eeuroparts was $510
1998 Olive Green V70 T5 Manual - 155k Awesome car
2003 Nautic Blue XC90 T6 3rd tranny - 162k Modded
2001 Nautic Blue C70 T5 Manual - 92k Not stock at all
Good news--
After replacing my air filter (K&N) yesterday, I was lucky enough to take a 75+ mile drive this morning. Just to test, I decided to fill upwith some mid grade gas as qwll. She's now reporting to get 295 on a full tank. Before the air filter change, car was saying about 220.
2003 Volvo XC90 T6
2007 Volvo XC90 3.2 (Wifey)
gshadow325
- Year and Model:
i dont know if the filter panel will net you that much gain. I do know for a fact that changing out the O2 sensors will net me a 20% increase in fuel economy. read my post here https://www.matthewsvolvosite.com/forums ... 58#p173658
- 1647 Views
Last post by dm635
- 1023 Views
Last post by lincolnshibuya
- 1487 Views
Last post by ilovemud
- 3184 Views
Last post by mctee
- 569 Views
Last post by Ozark Lee
