Hello everyone,
I am planning to install a cold air intake to my S80.
Has anybody installed one?
Any recommendations?
Any place to buy?
Thank you...
2000 S80 T6- COld air intake
neworleans
- Year and Model: 2007 S60R
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The car already has cold air intake. The hose from air cleaner box that runs over the top or radiator is connected to a duct that gets air from just behind grille. If that duct is missing then replace it. If the oblong piece that runs forward over rad is not there for the air cleaner duct to attach to then put it back.
The other thing is that on a turbo car a cold air intake does not matter unless it is replacing a very restrictive air filter that gets its air from a hot location. The air goes through the turbocharger and gets heated. Then it passes through the intercooler to cool it down again before going into intake.
A cool air intake with air cleaner can reduce restrictions in airflow but your volvo has a large air filter and is a very good one that has probably nothing to gain from being replaced.
yuckuJackD
- Year and Model: XC70; S80; S40
- Been thanked: 2 times
...and here are some pics of it:jimmy57 wrote:The car already has cold air intake...
On 2-nd pic I tried to show you the duct from the grille but ... only the grille is visible on the picture. Whith ot without flash - it's the same. sorry.
As seen in my signature the car is S80 2.9 200hp '00y. B6294S (Non turbo).
Good luck
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
neworleans
Thank you very much, you've acknowledged me very well on this...
hilldomain
- Year and Model: V70 XC, 2000
yuckuJackD if you want to take the second photo just focus on something that is the same distance away as the object you want to take a picture of by pressing the button half way and keeping it pressed half way. What I mean is point the camera away from the grill to something else the correct distance you want the focus to be (can be the ground or whatever) Then while still pressing it half way point it toward the inside of the grill and click. This also works when taking photos out windows or other parts in the engine compartment that are hard to see.
In other words you are focusing on the grill (when the button is half way pressed) therefore you are taking a picture of that.
hard to explain.
hard to explain.
yuckuJackD
I got the point, thanks for the tip.
- 935 Views
Last post by WannaBeOCer
- 2064 Views
Last post by S40Luckey
- 18 Replies
- 5773 Views
Last post by MadeinSweden1
- 1547 Views
Last post by 454cid
- 754 Views
Last post by doublebug
