how to remove the dashboard speaker grill
How to Remove Center Speaker on the Dash
I want to say it simply pries outward, but I haven't removed one of these in a while. If I am correct, and I think I am, you will want to get a bone tool or similar so you won't mar or indent the dash where you pry. Once you get one side of it up simply gently grab it and pull upward.
yuckuJackD
- Year and Model: XC70; S80; S40
- Been thanked: 2 times
Mind not to damage the dashboard.
Here you are:
Here you are:
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
Thanks for all your tips!!!
A few days ago when I tried to use a flat plastic stick to unclench the mesh, it didn't work and formed a small dent on the soft part of the dash. So this time I will try the way you suggested.
Thank yuckuJackD so much for such detail PDF file and again thanks a lot for otis44 and FCPGroton for your helpful suggestion!!!
I made a hook this time, removed the speaker grill and found the reason of the speaker noise.
There was a small piece of paper (a label) on the top of the speaker which caused some noise when I played the music loud.
- 7088 Views
Last post by Suchy101
- 5382 Views
Last post by hausmeister
- 3629 Views
Last post by Mastiz
- 505 Views
Last post by BlackBart
- 6997 Views
Last post by SuperHerman
