A bad thing happened last night while putting my left rear wheel back on my V70 R. The lug bolt broke in half.
Then a good thing happened, the bolt turned as I was drilling, so I simply backed it out with a center punch:
>>> Read the whole story <<<
Broke a Wheel Lug… Then Something Amazing Happened
- Has thanked: 2652 times
- Been thanked: 1245 times
ooops
[As an english comic would say "I Don't believe you wanted to do that" or "I Don't Believe it!!!"]
I had the same problem when I first got my T5 thankfully I simply removed the disc then pulled the remains out as UK Discs don't have the threads just the hub
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
