ABS Light
This topic is in the MVS Volvo Repair Database » Water Pump Replacement 2002 S60 N/A
ChrisG75077
Year and Model: 1998 S90 Blackberry
Post by ChrisG75077 »
My next option is a Black Sharpie to color the indicator light!
The ABS light comes on sometimes at start up. If I shut off and re-start SOMETIMES it is off. What? help?
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
You have an ABS fault. That system can give codes but if the light in on immediately at start it is usually an open circuit in wheel speed sensors or the power supply relay to solenoids on the modulator/pump unit under hood on passenger's side.
ChrisG75077
Thanks Again! I will check both possibles!
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
The ABS on my 88 760 acted up. When the light was on the ABS worked fine. When the light was off it acted up. I cleaned the tone rings on the front hubs in June 2009 and the ABS is still functioning fine.
1988 Volvo 760 Turbo Wagon
