Hot Buns (Seat Heater Woes)
rp850
Post by rp850 »
Anybody ever have their seat heaters stay on even though the switch is off? I was warm here today (80s) but I could swear the seat heater was on even though the switch was off. I was roasting!
Can I pull the fuse or the seat connector as a test to see if my buns cool down? Summer is coming and I've got to do something!!!
Thanks!
Jot
Year and Model: C30 2010
Post by Jot »
Volvo has a recall on the seat heaters to install a thermostat. meantime they can be unplugged under the seat.
rp850
Post by rp850 »
Thanks Jot. I'll look into that. I thought to disconnect it but there's a bunch of connectors under the seat. Afraid I'd set off the SIPS bag or something. Is there an easy way to tell which connector it is?
rp850
Post by rp850 »
Jot,
I looked on the NHTSA website and the recall you describe is only for the 1996 model year. I have a 1995. Have you heard of anyone with this problem on a 95? I doubt the dealer will even look at it if it's not covered under the recall but I'll give it a shot.
Thanks,
rp850
wildatheart
Post by wildatheart »
There is a round opening in the foam, about 1.5 inches across, in the centre of where your bum rests. There are two wires going into this opening, and if you crane your neck and press the foam down , you might just be able to see the connector.
1965 Volvo 122S
1970 Mercedes W113 280SL
1971 BMW 2000 Touring
1986 Ford Capri 280 Brooklands
1994 Volvo 850 20v GLT
rp850
Post by rp850 »
Thanks! I'll check it out.
Black850
Post by Black850 »
By the way, I'm pretty sure the heated seats recall was expanded to all years. I have a 97 and got a letter for it so you might just want to call the dealer and ask.
rp850
Post by rp850 »
Thanks! I'll ask about the recall.
