CEL its missing again
pdorestan01
Year and Model: C70 1998
Post by pdorestan01 »
I have a 1998 c70 coupe and I changed the spark plug wires ,wires distributor and rotor cap ran fine for 2wks then started missing again, when I first did the tune up I found moisture and water in the cap,could there be moisture in the cap again is there a seal there that could have gone bad? it runs fine now but sometimes it misses again .
misha
Year and Model: '97 850 2.5 20v
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
What brand did you use for parts?
Bosch for distributor & rotor cap,Bougicord for wires and oem Volvo spark plugs or just cheap Bosch spark plugs but gapped correctly are the ONLY way to go.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
pdorestan01
thats what I put in there. volvo plugs
misha
Post by misha »
Is your car turbo or non-turbo?
Volvo spark plugs are different for those two engines and it's clearly written on the spark plugs pack.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
pdorestan01
turbo I got the tune up kit from FGP
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Is it a misfire on multiple cylinders or just one?
It may be the beginnings of a camshaft or crankshaft position sensor going bad. Check to be sure that your camshaft sensor wire is as far as possible from the distributor feed wire. It is the sensor located just to the rear of that one, also with a fat black insulated wire.
'98 S70 T5
2016 Chevy Cruze Premier
pdorestan01
i THINK the reader said 300 and 302
