''SRS AIR BAG SERVICE URGENT, CHECK ENGINE, SERVICE, ABS''
chidi4volvo
- Year and Model: S80 2000
HI GUYS, I DRIVE A 2000 S80, THE MILL IS ABOOUT 154K. THE ABOVE MESSAGES KEEP ON POPPIN UP EVERYTIME I START THE CAR. PLEASE WHAT IS THE MEANING OF THOSE MESSAGES. AND HOW CAN I REMOVE THOSE LIGHT BECAUSE IT IS QUITE DISTURBING NAD WHAT POTENTIAL DANGER DOES THESE POTEND. ANSWER NEEDED ASAP. THANX.
yuckuJackD
- Year and Model: XC70; S80; S40
- Been thanked: 2 times
Replace the battery. While starting the car these modules remain with less power then needed and that's why you see the errors just while starting the car.
Make a check - is abs working property? If yes, then this module is OK. Other things are hard to be checked.
Good luck
Good luck
A member of VolvoClub Bulgaria
Of All The Things I've Lost,
I Miss My Mind The Most.
VOLVO 440 1.7i 89y. B18E
VOLVO 460 1.8 mono 91y. B18U
VOLVO S40 1.8 115hp 16V 97y. B4184S
VOLVO S80 2.9 200hp '00y. B6294S
VOLVO XC70 D5 185hp '06y. D5244T4
chidi4volvo
thanks Yucku, i changed the battery in december, 2010. the lights show from time to time even while the car is moving. the ABS and Check Engine light started showing after they worked on the front suspensions and the steering stabilizers. someone suggested taking the car for scanning. i really dont know what to do.
yuckuJackD
Bad connecton of a socet?
Perobably the instrument pannel... just thinking...
