Valve Cover bolt tip broke...
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
diyer97
Year and Model: 960 97 138kmiles+
Post by diyer97 »
when I overtightened it (just one of them). What do I do? Please give me some advices..
Thanks,
Ken
danr960
Year and Model: 964 1994
Post by danr960 »
Are you saying the end of the bolt broke? I find that hard to believe, because the bolts are tightening into soft aluminum, so the bolt hole would strip out first before the bolt would break, but I guess anything is possible.
The 50 something bolts that hold the head top on do not need much torque to be tight, and they do not tolerate any over torquing at all.
If it is just one bolt that the tip broke off, I would replace it with a shorter bolt, if the broken piece is farther up the hole and will not allow another shorter bolt to be used, then go with out it. There is a sealant/glue that holds the head top on, if fact, you could probably remove all of the bolts and the head top would stay in place, that glue is so strong.
DanR '94 964 356,000 miles (122,000 on the new engine)
diyer97
Post by diyer97 »
Thank you, Danr960!
In fact the car involved is not a volvo; the tip with the threadings is about 1/4inch and this part broke and I can pull
the bolt head out...Hoping it's OK like you said..
