problem with fan volvo s60 2.5T
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
cyc13
Year and Model: 2006
Post by cyc13 »
Hi, I have a problem with my volvo s60 2006, the fan will not turn on, and I left on the car for an hour and the temperature is in the half, I walked around and the temperature go up but the fan never lturn on, I thought the fan was bad, i buy another fan, but still not working, and check the fan relay and it is good.
My question is what problem I have and how I can test the fan? as it has 4 spikes, the which I know there are three running, one red, one black and one purple.
Another problem could be and what else should I check?
As an additional information i use my scanner OBDII and i get the code P0102, it is a code related with my fan problem?
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
Have you checked the fuse? I know it sounds silly but I have to ask. Also, the temp sensor could be bad and not giving the car a good signal.
