2001 S60 thump on start and shutdown
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
ashgoldS60
Year and Model: 2001 S60
Post by ashgoldS60 »
Have 2001 S60 with Base 2.4 motor(nonturbo) and only 33K miles. When starting the engine and shutting it off there is a noticeable thump. Just got the car and replaced the top torque stabilizer bushing. No change in noise. No vibration when running. Are these 5 cylinder motors just noisy when starting and stopping?
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Your bottom mount (lower right of car) may be prematurely bad.
When you change one and don't check the other, all the movement travels to the weakest mount,
ie: the oldest, and if that's also bad you can/will hear some noises
To answer your question...NO it should not "thump"
You also have a rear tranny mount to check but at your miles I doubt that is bad.
Something is broken that shouldn't be at 33K miles
At 33K miles it should be quiet as a mouse and NO thumps!
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
I would check all the mounts, it sounds like a least one of them is bad. Just because the car only has 33K on it, it is 10 years old so age is a much bigger factor here.
