Control Arm Bushings - DIY Possible?
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
boosted5cyl
Year and Model: '98 V70 T5, '99 S80
Post by boosted5cyl »
Do I need a hydraulic press to replace the bushings in the control arms or will heat and brute force work? 150ish/side is more than I can stomach so if I can do the bushings myself I would be a happy camper.
'04 XC90 2.5T AWD (Angus) 134K.
'99 S80 T6 (Medusa) 214k. On borrowed time LOL
'98 V70 T5 (Vivienne). RIP @ 228K. Spun rod bearings.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
knock the broken center out and then go after it with sawzall. After you cut through it falls out.
Large C clamp, proper size iron pipe coupler a little larger than the OD of bushing, and another coupler or 1/2 inch socket that is a small fraction smaller that ID of hole in control arm can be used with C clamp as press. You probably need at leat a 10 inch clamp but 12 inch would even be safer depending on height of your fashioned press drifts.
ed7
Year and Model: V70XC 2005, 2001
Has thanked: 2 times
Post by ed7 »
A vise will work well. A decent vise, mounted, will give you one hand to hold and one to crank the screw with.
An arbor press works also. Just start the new bushings as straight as possible; it makes things easier.
Use sockets or tubing or pipe fittings to help drive.
Sawzall is one of my favorite tools.
Ed
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1254 times
Post by matthew1 »
I tried it without good tools and didn't get far. I got the old bushing out with lots of elbow grease and a hacksaw. If you have a good vise and sawzall, go for it.
Also -> Amazon link
bobsnow100
Post by bobsnow100 »
I've put the new bushing in with a large vise and the right size socket . What I do to put it in straight is to just grind a very small bevel around the outside of the whole round edge of the metal bushing and it will fit in the control arm and not want to tip sideways when pressing it in.
I have also heard that if you put the bushing in the freezer to get it cold that it actually makes it easier to get in.
boosted5cyl
Yeah I was thinking freeze bushing, heat control arm, cross fingers.
