99 S80 surge
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
Mr Craig
Year and Model: S80,1999
99 S80 surge
Post by Mr Craig »
My 99 S80 2.9 surges upon acceleration and also at speed. An auto parts store code reader read that "bank one system to lean" and "bank two system to lean". I cleaned the ETM a while back so I don't think that’s the problem, but what’s the deal with bank one and two on an inline 6?
jimmy57
Been thanked: 320 times
Post by jimmy57 »
bank one is cylinders 1-2-3 and bank two is cylinders 4-5-6.
There are two front O2 sensors and the fuel mixture (fuel trim) is split.
99 S80 2.9 is somewhat prone to MAF sensor failure and until it gets way out of range there will not be a MAF code but it can run lean. Fuel pressure is also a concern for those codes when set on both banks.
Someone with experience and VIDA or some scan tool capable of full fuel system readout can figure it out. MAF correction factor is usually off too far on bad MAF cars.
