I'm looking to buy an Equus 3030 Innova Diagnostic Code Reader for OBDII Vehicles to help me diagnose some problems with my 96 850 Turbo. From the reviews this looks like a good model thats within my budget, does anyone have experience with this reader ?
Also does my Check Engine Light have to be on to troubleshoot and diagnose issues as the vehicle currently won't start ? Lastly does anyone have a file or link that can point me in right direction to get code descriptions for a 1996 850 Turbo ?
As always thanks for your help , I love this forum and am learning quite a bit from all of you !!!
OBD2
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
https://www.matthewsvolvosite.com/volvo- ... ble-codes/
That scanner should work just fine. If the car has codes stored, they will come up on a scan even without it running. Then again, if there's something wrong with it that it doesn't know about because it's unable to start and run through the checks, you might not see anything show up.
This is a horribly outdated list, and we are working on a new one. But if you have any questions on codes that you don't see there, just post up the code numbers and someone will try to get you an answer.
'98 S70 T5
2016 Chevy Cruze Premier
Thanks , I'm going to try the things you suggested in my other post first as far as the injectors go and determine if i'm getting spark as well. I think i'm still going to pick up this code reader as well to have for future use as this is an older model i'm wanting to invest in. SO these code readers can/will read codes even if they haven't set off the Check Engine Light for me to see yet ? Is that a correct/incorrect statement ?
jblackburn
If there are pending codes stored in the computer, sure. It takes multiple occurrences of a code for the car to set off the check engine light. However, IF the car hasn't noticed that anything is wrong before it wouldn't start, you might not have any codes stored.
'98 S70 T5
okay got a code P0120 and after some searching found this definition ..... Throttle/Pedal Position Sensor/Switch "A" Circuit
So what does this mean exactly ? What are some things i need to do to try to resolve this code and try to find the exact cause ?
My problems started with a bad starter , car was running fine before that, I changed the starter and engine turns over good, just never cranks up, is this trouble code enough to prevent start-up ? Is it a fluke that it happened after a new starter install or does this make sense?
Thanks as always !!
Thanks as always !!
jblackburn
Check the wire to the throttle position sensor - it is just behind the radiator on the front side of the throttle body. If it's connected and the contacts are clean, then it should be replaced. That could be enough of a cause for it not to start I think. You probably just knocked off the wire or forgot to reconnect it when you went down there to replace the starter.
'98 S70 T5
ok checked TPS , it was plugged in. Replaced TPS and still reads same code, i disconeccted coil wire from distributor cap like you suggested and turned engine over removed a plug and could not feel or smell gas. I checked for spark after reconnecting coil wire and i don't have spark even after replacing plugs. I'm really stumped if you or anyone has any suggestions !!!
ok, just got off the phone with a friend and told him everything i tried. I forgot to mention on my original post that when i hooked my wires back on starter after install and connected the battery the car started turning over on its own but not cranking with no key in the ignition. I dissconnected battery and fixed wiring problem and now it turns over but doesn't start. My friend said i might have set off the anti-theft system ? Do you yhink that is why i'm not getting any spark ? If so how do i fix this so me and my volvo can get on with our lives and driving ? PLEASE HELP
jblackburn
That could have done it. I (think) that when I set my alarm off nearly 2 years ago by unlocking the car from the door, it wouldn't let me even engage the starter. I honestly don't remember that well except frantically trying to get the car to quit honking
If you have a remote, lock and unlock the doors with the remote. If you don't, stick the key in the drivers door and do the same thing (car locked first). This should, for the most part, reset the alarm system. If still nothing, try the same procedure 3 times in succession.
'98 S70 T5
jblackburn
Because of that comment, I would suspect a failed cam position sensor if you are unable to get it running again.i disconeccted coil wire from distributor cap like you suggested and turned engine over removed a plug and could not feel or smell gas. I checked for spark after reconnecting coil wire and i don't have spark even after replacing plug
If you've got the little red light on top of your dash like my S70, if the alarm system is preventing the car from starting, that light will be flashing furiously rather than every few seconds when the alarm is armed.
'98 S70 T5
- 959 Views
Last post by Lowmiles
- 3852 Views
Last post by vtl
- 29 Replies
- 19920 Views
Last post by esl_97_850_T5
- 581 Views
Last post by doa202
- 800 Views
Last post by Lochaberlaird
