Hi, I recently got a 2001 V70 T5-M that has a little lifter noise for about 1 second, if the car sits overnight. My 98 S70 T5 is quiet upon start up and idle...
Is my 2001 T5 model more prone to lifter noise at start up compared to my 98 T5? Both cars are about 100,000 miles. The lifters are fine after the inital start up. Thanks Rob
First start lifter noise
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
What weight oil are you running in the '01?
'98 S70 T5
2016 Chevy Cruze Premier
- ignatz
- Year and Model: 2006 S60 t5m
- Has thanked: 17 times
- Been thanked: 33 times
I bought it with a fresh 5-30 oil change, ran it for about 1,000 miles and changed it to 10-30 with slightly better results. Both oils were standard Pennzoil dino.
2002 V70 2.4
2005 S60 2.5t awd
2006 S60 t5 stick shift
2005 S60 2.5t awd
jimmy57
- Been thanked: 320 times
2000 and later have solid tappets. No hydraulic lifters to make noise. It could need a valve adjustment. The adjustment method is measurement and selection of correct dimension tappets.
It is not unusual for noise until engine warms up as exhaust runs a wider clearance to allow for stem growth which occurs on the hotter exhaust valves.
- ignatz
Thanks, I was not sure if I'm having the beginning of o-ring problems in my oil pan allowing the system to bleed down. My oil light goes out right away..hot or cold. Doy you only worry about the oil pan o-rings until the oil light flickers?
2002 V70 2.4
2005 S60 2.5t awd
2005 S60 2.5t awd
jimmy57
Usually failed o rings in oil pan will have oil light flickering on hot engine. The oil light will flicker when cooling fan comes on or any other load that momentarily dips engine speed a little.
- ignatz
Thanks, I really love the wagon and want to make sure the noise was normal. With 98,000 miles, the timing belt and pcv system are getting done real soon. Thanks again, Rob
2002 V70 2.4
2005 S60 2.5t awd
2005 S60 2.5t awd
