940 air temp sensor
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
gomocs
Year and Model: s80 2004
940 air temp sensor
Post by gomocs »
I own a 95' 940 non-turbo that has been running rough at idle, low hp, just sounds bad almost like puttering, and would occasionally die at stops.
I replaced Battery and Alternator (got 230,000miles out of alt.) month ago,air filter, and fuel filter a year ago.
A couple of months ago I got error codes 2-1-2 (o2 sensor), 1-2-2(air temp sensor), and 1-1-3 (fuel injector) if I have the codes correct.
The car uses the pulsar valves, one was bad- went to a garage that restores Volvos for a used part- He told me just to plug them up. At $340 EACH from the dealer I didn't argue.
I replaced the original o2 sensor and that got rid of the 2-1-2 code.
I then checked for vacuum leaks, flame trap hose was in bad shape even though I replaced it a year ago, and one cracked hose on the throttle body. This helped the car somewhat.
Cleaned the throttle body which made little difference.
The 1-2-2, air temperature sensor, I cannot find for the life of me. Even the parts guy at the dealership could not pin point its exact location. I noticed several other postings with a similar question but with no clear response. I thought maybe I might have some luck.
The car has started sputtering as it slows to a stop. I also hear a rattle under the car from time-to-time as well....catalytic converter gone bad?
Any guidance would be GREATLY appreciated!!!
Todd
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
1-2-2 is a Regina code. If the signal from the air temp sensor is too high or too low the car goes into limp home mode. The sensor is in the big hose coming from the air filter, part #19 in the attached.
940 Regina Air Temp Sensor.pdf
(80.65 KiB) Downloaded 999 times
Check the contacts in the connector for oxidation and clean them if necessary.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
