engine sludge problem
is it true that the 01 t5 2.3l engines are notorious for sludge build-up??
1997 855R-Completely Bone Stock..for now
JRL
- Year and Model: Several
- Been thanked: 16 times
Yes if the oil was not changed regularly and/or the car not driven on the highway much, nice and warmed up, and often
JDS60R
- Been thanked: 3 times
Clean using a high quality flush only such as:
http://www.amsoil.com/storefront/flsh.aspx
Most flushes do not do the job of holding the broken down sludge in suspension. If really bad after the first flush then flush it again at next oil change. us e a quality full synthetic oil that won't burn off or breakdown. Many motors can be run with great success after a flush but some are so far gone that the damage the sludge caused becomes clear. Excessive sludge, non maintained coolant and long term un repaired fuel ratio or ignition issues are markers of an early death for any engine.
Retired
JDS60R
Only those that don't maintain it properly. Use it as a marker to show how the last owner took care of things. I just went to buy a 98 V70 XC for a friend but with black trans fluid and obvious sludge in the engine it was very easy to walk away.
Retired
jimmy57
- Been thanked: 320 times
There is no sludge "problem".
ALL engines with poor oil change history will have failed oil that degrades and leaves sludge.
That engine has oil spray jets under pistons to cool pistons but it also diminishes sludge from oil hitting hot piston crown underside.
I do not know of any make of vehicle that has an engine that does not have sludge issues from too long oil change interval for the usage or from extensive idling in cold weather.
JRL
Yes and no
I agree that almost any motor if not properly serviced will sludge up.
The problem is that many people thing that Volvos run forever and they can... for a very long time, but their oiling system requires a bit more servicing than the average modern engine.
