Transmission Leak
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
shookone
Year and Model: 2001 V70 T5
Transmission Leak
Post by shookone »
I took my car for an oil change and my mechanic says that I have a transmission leak. Need to replace both axle seals and a right axle. Now my transmission has been slipping from rev to drive and in third gear, only after the car is warm. The fluid level seems high and the color isnt bad. I have read posts about doing a flush which i bought the kit yesterday. My question is should i get the axle seals fixed before i do the flush? Seems pointless to flush if it leaks.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Yes.
Make sure you only use 3309 fluid in this car.
If the fluid level is too high, it can do just as much damage as having it too low. At the same time, call a dealer with your VIN number and ask if the 2001 transmission software update has been done on this car.
'98 S70 T5
2016 Chevy Cruze Premier
sooner1
Year and Model: XC70 2001
Post by sooner1 »
Do you check the ATF when running, or with engine off/
