Parting Out:
1993 Volvo 240 Sedan
190,XXX Miles
Purple Exterior, Tan cloth interior
Vehicle is located in Denver. I'll gladly ship parts, if they can be. Or will deliver for just fuel $$
Mechanically sound, ran and drove 65mi to where it's being parted out. Even pulled my Ford Ranger 3mi up hill to a shop and didn't heat up.
Parts that are in good shape:
Motor in great running condition.
190,000 miles on it, $400
Automatic transmission, comes with relay and overdrive solenoid $250
Runs, shifts, drives fine, I have the shifter gate as well.
Rear axle, complete disc-to-disc $200
Driveshaft, full length $50
Fenders $40ea
Doors WHOLE $50ea, all have good glass, all have good window regulators, arm rests.
Drivers missing door panel.
Trunk lid
Front bumper and air dam, NO damage! $50
Rear bumper has minor plastic damage on one corner $10
Headlight Lenses, minor haze $10/ea
Drivers Turn signal lense (CLEAR, GREAT shape) $15
Grill, no logo, $20
Rear glass (YOU remove : ) $20 perfect
Windshield has 1 chip, if you want it you pull it and it's yours for $10
Driver air bag $100
Front Seats $100 for the pair. Great shape, no rips, no stains. Tan cloth.
Gauge Cluster (perfect) $50
Heater/AC control unit with little hoses and fittings still on $20
Drivers Door Window Switch $20, Other 3 window switches together for $20
Locks: (4), ignition, both front doors, trunk (1) working key$100
Engine ECU Unit, BOTH pieces (on passenger kick panel AND firewall)
Part number ending in 951, multi-squirt, you want this one to swap into yours $150
Mass Air Flow Sensor $50
Fuel Pump Assembly, pickup, gauge sender, $50
Brake booster and master cylinder together $100
ALL relays and switches available
Pics available upon request for any part.
Give me (Saul) a call at 303-919-7769, anytime.
Thanks for looking and happy hunting.
I check phone more than I check on Matthews, but I'm here at least once a day to check PM's
Parting Out 1993 240 Purple/Tan Colorado
Gumcrew2
- Year and Model: 96 850 GLT
"When Murphy wrote his law he was thinking of you"
96 Volvo 850 GLT GONE (replacement coming soon)
91 Jeep Cherokee 448K, Turbo Stroker, Lifted, Locked, Caged.
83 Ford Ranger, F250 brake system/ sway bars : )
l8forthesky
- Year and Model: 244, 1993
Hi,
I need the AC pressure switch. It's located, when facing the engine compartment, on the left side by (below) the lower radiator hose. It's grey in color and has a squarish end to it. I attached a picture.
Thanks,
Patrick
Thanks,
Patrick
- photo.JPG (115.74 KiB) Viewed 724 times
