Just got a lab test back for the oil.
"excessive antifreeze in the oil"
I'm thinking oil cooler.
No visible milkiness, and I did a block test for exhaust in the coolant (head gasket OK).
Anyone have any experience with this?
Thanks,
Oil cooler leaking antifreeze into oil?
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
I have seen it happen. But I don't think this car has an oil cooler inside the radiator. What engine does yours have? AWD or FWD?mgjonesin wrote:Just got a lab test back for the oil.
Thanks,
2008 S80 T6 AWD
1999 S70 GLT
1999 S70 GLT
precopster
- Year and Model: Lots
- Been thanked: 128 times
All Volvo straight sixes have an oil cooler. This is either a separate unit or integral with the radiator.
Either replace with an aftermarket oil cooler (by bypassing the factory one) or replace the entire cooler. Do you tow?
precopster
If it's not integral with the radiator then you have a problem.
The only other thing available might be the head gasket.
Just because exhaust (carbon monoxide) is not in the coolant it doesn't mean a breach of the HG b/w engine oil and coolant jackets hasn't occurred.
You would be testing for (CO) only if you saw excessive bubbles in the coolant reservoir or overpressurisation of the coolant system.
The oil cooler is not integral with the radiator but it has coolant running through it. It's not a air to oil cooler, it's a antifreeze to oil cooler. Coolant is pipped to a manifold at the back of the engine that supplys the oil cooler and the turbos.
precopster
That must be an immense relief to you!!
voodoorobaz
- Year and Model: 1982 Volvo 245 DL
I Have had same symptoms in my 2000 volvo xc70. It was the oil cooler mounted to the oil pan. They reason you have oil in coolant and not coolant in oil is this. Oil pressure is 25-80 psi and coolant is around 16psi. Oil cooler has micro cracks which allow oil to leak at a psi greater than 16, Hence oil in coolant. I hope this makes sense. I troubleshot it by getting a small pipe, taking both coolant hoses off of oil cooler and connecting them together. Now start the car and watch oil cooler tubes and you will see oil coming out which won't take long at all.
1998 Volvo S70-Gone
2002 Volvo S60 T5-Gone
2000 Volvo V70 XC AWD-Gone
1983 Volvo 245 Dl-Gone
1982 Volvo 245 DL
2013 GMC Terrain with 3.6l
2006 Cannondale Bad Boy Use for Commuting to work
1982 Volvo 245 DL
VCA
Yup, and when you see oil coming out, it's part 30622090 for the cooler. Change the gasket as well, that's part 30637339.voodoorobaz wrote:I troubleshot it by getting a small pipe, taking both coolant hoses off of oil cooler and connecting them together. Now start the car and watch oil cooler tubes and you will see oil coming out which won't take long at all.
2008 S80 T6 AWD
1999 S70 GLT
1999 S70 GLT
- 2089 Views
Last post by fitz548
- 1588 Views
Last post by SuperHerman
- 2202 Views
Last post by cn90
- 2683 Views
Last post by StubZz
- 1341 Views
Last post by cn90
