2003 XC70 possible purchase
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
jbrown122
Year and Model: 1999 V70, 1995 850
Post by jbrown122 »
Hello all, looking at another wagon.
It's an 03 XC (with 140K), pretty clean. Drives nice, the tranny and engine are extremely smooth, I took it for a long ride today. The t-belt was done a year ago.
The brakes were loud when it was cold, he'll replace them- takes bumps good but knocks in the front end (he'll also fix it, it's a small dealer).
Probably will need tires soon. HOWEVER! One thing that turned me off "SRS Airbag Service Urgent" MESSAGE is on, but! the red airbag light is not on. Why is that?? He said he'll check it out as well.
If those things get squared away, then I think it's worth it. $5900. Do you?
Or, I can go for a 04 XC for a few hundred less, with 155k that is almost mint.
What do you guys think. Any tips, pro's and con's about the XC?
What do you think of the 03 (mainly what about the SRS issue) Thanks all!
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
If I were you, I would go with the 04 model as long as the maintenance is up to date. I know the ETM issue was sorted out by then and the AWD was a lot better. Also, the SRS issues scares me.
jimmy57
Been thanked: 320 times
Post by jimmy57 »
03 does not have ETM and 2003 and 2004 use the same generation Haldex AWD coupling (Volvo lingo, Active On-demand Coupling)
Which engines are in the two?
Are they FWD 5 cylinder, AWD 5 cyl., or the 6 cylinder AWD?
jbrown122
Post by jbrown122 »
Both wagons have the 5 cylinder turbo with AWD
jimmy57
Post by jimmy57 »
The 04, cleaner but with 15K more miles, but less money seems to have a few more points going for it compared to the one year older with noise in front end and the SRS warning message.
jbrown122
Post by jbrown122 »
Makes sense. But do you think I can get about 50k out of this car with just some small repairs along the way?
(It has just had a new tbelt, brakes and tires done from Volvo)
I'd like to know about the AWD system, supposedly it's not as troublesome as the 98-02 system.
And the electronics, I haven't heard of many problems with the electronics with the newer models.
Thanks for the help so far!
jbrown122
Post by jbrown122 »
Well.. the 04 is sold (always happens..)
Maybe I should drop the 03 and keep searching?
