Amazingly well documented Odometer Fix
This topic is in the MVS Volvo Repair Database » How to Fix the Odometer on your Volvo 850
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2854 times
Been thanked: 1332 times
Post by matthew1 »
Many thanks to Rox for this fine series of photos and text on how to fix an 850s odometer.
>>> Odometer Fix <<<
Fantastic. If anyone has comments, please add them here.
Also -> Amazon link
Jot
Year and Model: C30 2010
Post by Jot »
Excellent photos and write-up
paedur5
Post by paedur5 »
Excellent work. I wish I'd seen this last week as I've just done this job.
I suggest changing the bulbs in the dash. They are cheap and you don't want to have to do the job again for the sake of a couple of blown bulbs.
Also I removed the whole dash top - it's only one more torx screw (I think it's only one at most two) and the subsequent instrument panel removal is a whole lot easier.
For turbo models - don't forget to remove the vacuum pump line from the back of the turbo gauge. If you can't get it off - don't force it as it can break. Go below and find the other end of the line where it's easier to seperate. It's under the footwell panel - a flexible rubber hose attached to a hard plastic tube. If you aren't sure which hose just follow it back up to the gauge.
Guest
Post by Guest »
Agree. Well documented. Let me think about tackiling this project, however. There is an advantage when you go to sell it. ; ) Nah, I'll have to come clean... (what's that saying, "Let the Buyer Beware" or somesuch). Will probably just pass down to my daughter if she still running decently. All this for a little yellow plastic gear. I guess all car companies decide to cut costs somewhere. I think I'll finally try to get my glovebox open for the next project so I can get to know my owners manual again after a coupel of years...
Appreciate the other posts also offering refined dash removal techniques.
wadeli
Post by wadeli »
Outstanding documentation of Volvo odometer repair procedure.
BTW, is there a risk of activating the passenger side air bag during the odometer repair process?
95autoturbo
Post by 95autoturbo »
sorry, i will look again but, how do i get a new gear? or where does it come from?
yes......It is an 850!
roxen
Post by roxen »
Thanks for all the great feedback! I don't think there is an airbag issue...if there is it was never mentioned in the video that came with our part, and my husband wasn't concerned about it as that area is well below where he was working on it. We ordered our part from www.ipdusa.com, but I would imagine it can be gotten other places as well!
FATWORM
Post by FATWORM »
Great! Thanks! I found this very helpful.
the TOOLS required are:
torx(star pattern) wrenches (t5 and t10 I think)
SMALL phillips and standard screwdrivers
Part:
the gear(available at odometergears.com and eBay)
I'd also like to mention that the vents are easily taken off by continuing to rotate them until they point at the floor. Then you can pull them out.
I'm not a mechanic and it only took me a couple hours and was easy.
Chris
loailila
Post by loailila »
I blind folded myself and I followed the instructions and they were excelent.
spdykat
Post by spdykat »
For the person who posted as Guest above, re: trying to open your glovebox, there is a really awesome set of instructions on that fix, created and posted by Yeagermeister on another thread entitled "94 850 Glovebox frozen shut"...good luck.
It's reassuring in a weird way to know that mine is not the only 850 with a permanently frozen odometer (164,450) and a permanently locked glovebox. Today I took it to the dealer for the fuel tank recall fix, and one of the mechanics said, hey at least it's still rolling, right? haha, whatever.
94 850
