V40 Rear shock crash course
This topic is in the MVS Volvo Repair Database » Replace Volvo Headlight Wiper Blades
mtroxel
Year and Model: 02 V40
Post by mtroxel »
Volvo noob here, but not new to wrenching. Did a V40 timing belt last weekend with help from this DIY and it wasn't too bad as timing belts go.
Girlfriend has 02 V40 and lots of noise from the RR suspension. Opened her hatch and found the top of the shock poking through the trim in the cargo area. :shock: I'm pretty sure that's connected to the problem. :idea:
Searched and can't find a good write up on changing the rear shock mount on a V40. I found this on a 98 V70.
Questions:
  • Is the V40 similar to this?
    Is the spring compressed or do I just jack a little underneath it to get it off?
    Does the V40 have the same problem everyone talks about with the welded nuts for the shock mount?
    I also see Volvo owners talk about replacting a spring seat. Is that just on the fronts or is that an issue on the rears also?
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
It's good to meet someone who searched first. :)
The top of the rear shock should be poking through the floor of the cargo area but not through the trim. Attached shows how to remove the rear shock and spring. You could probably spring compressors instead of the special tool.
V40 rear suspension replacement..pdf
(651.37 KiB) Downloaded 1920 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
mtroxel
Post by mtroxel »
Nice Bill. Perfect. Something tells me I can do w/o disconnecting the sway bar if I just lift both back wheels so it can all hang? Or is that a "must"?
billofdurham
It is a "must". If you don't remove them you won't have enough clearance to pull the spring through.
Bill.
Previously:
mtroxel
Post by mtroxel »
K. Thanks a lot Bill.
