CODE P0172
Volvo MAF Sensor Problem Solved
dimasp28
- Year and Model: 850 glt 1995
Hi everyone !!! I'm Dimas and I own a '95 850 glt with 191,000 miles it runs very well, one month ago I did a tune up and changed the Maf sensor; this afternoon the check engine light turn on and I was near to an Advance Auto Parts Store so they check it and it shows the code P0172 and also said "bank 1 too rich" . Can somebody tell me what this mean and what I should do? Thanks in advance
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Time to start checking for vacuum leaks! Look at any of your vacuum hoses on both sides of the intake manifold for cracking, split hoses, missing elbows, etc.
If you can't visibly spot anything, a can of carburetor cleaner sprayed around the lines will tell you if there is a leak if you hear the engine idle rev up a little bit.
'98 S70 T5
2016 Chevy Cruze Premier
- 3025 Views
Last post by charleskennedy23
- 5813 Views
Last post by matthew1
- 1429 Views
Last post by Cukhe2000
- 981 Views
Last post by pgill
- 1595 Views
Last post by xyourobob
