Cordless impact tools
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Anyone found one of these they like?
I'm looking at the Porter Cable 18V version because I have a drill that uses the same battery and can get it for a lot cheaper without the battery.
http://www.lowes.com/pd_159330-79992-PC ... s%2Bimpact
I'm thinking it could be a big help if I need to start removing stuff; keep in mind I'm working on this thing in the parking lot with no access to air or an electrical outlet.
'98 S70 T5
2016 Chevy Cruze Premier
zhenya
Year and Model: 97 855 T5,98 V70 AWD
Post by zhenya »
Guess it depends on what you are looking to use it for? There is no specs on that particular model, but the Dewalt 1/4" impact driver, the max torque is measured in inch/pounds. Fine for smaller bolts, but it's not going to get the larger, really stuck stuff off. Something like this, with 300 ft/lbs of max torque is a lot more equivalent to an air tool: http://www.lowes.com/pd_269802-70-DW059 ... s%2Bimpact
We use these to remove wheels quickly for track days and have had good luck with them. Obviously a different class of price, but might be a lot more useful, too.
caz2773
Year and Model: 98 V70r
Post by caz2773 »
i picked up a snap on cordlees impact and ill tell you this a bit pricey but really worth it removes any bolt anywhere that is stuck, hub bearing, wheel lugs, k frame bolt, motor mounts anything but be careful it has a lot of power so it can break bolts i mainly use it for really hard stuff lije steering rack it was a pia to get under the car and unndo the bolts but with this it took about 30 to 45 uninstall and intall good product tool # ct8655 18 volt impact wrench
jblackburn
Oh. Duh, Justin. 1/4" are those little bitty sockets :roll:
Most of my sockets are 3/8" anyway; I have an adapter that will convert down from a 1/2". I'll stop through Lowes on my way back from the junkyard tonight and poke around. Harbor Freight might have some too and I need to make a stop in there for a few cheap wrenches and stuff, but I don't buy electrical tools from them.
Such an investment will probably come in handy for changing struts and other suspension things too. :wink:
'98 S70 T5
zhenya
Post by zhenya »
A couple more thoughts - those 1/2" to 3/8" adapters probably won't hold up to impact use - I've sheared them off just using a regular socket wrench. Impact tools really should use impact sockets anyhow - you are prone to destroying your sockets otherwise.
jblackburn
Look what you've done; you've given me an excuse to go tool shopping :mrgreen:
I broke 2 Craftsmen socket wrenches just trying to get a freaking hub bearing off (not the axle nut itself; that was a whole different story), so you're probably right!
'98 S70 T5
anjill182
Year and Model: 98 XC,98 AWD, 95 T5R
Post by anjill182 »
While you're at the jy, don't for get to pick up that extended elbow that connects the plastic tube from the oil seperator to the ptc from a 99 or 2000.
Year and Model: 2004 V70 2.5T
Been thanked: 467 times
Post by cn90 »
I have an air compressor and use air tools.
Do you think cordless is better than air tool?
Just curious!
zhenya
Post by zhenya »
No - the wrench is a lot bigger, and battery life is not all that great - but for those who don't have a compressor, or a place to put a compressor - or for things like track days, the battery powered units are great.
ChiNorm
Post by ChiNorm »
FWIW, if y'all want an impact wrench for automotive use, you want one with the 1/2" shank, not the 1/4". And you do want to use the proper sockets unless you want to destroy them. It is a handy thing.
