manual boost controller 94 940
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
mojomello
Year and Model: 1994 940 turbo
Post by mojomello »
I just installed a boost controller and I'm not seeing signifigant boost increase. I don't wanna crank it up too high and blow my motor, but just out of curiosity, are there any factory presets that I need to bypass? There's gotta be more to this than simply slapping a valve onto the turbo... It never goes any higher than about 1/8 into the white on the stock gauge
mojomello
Post by mojomello »
nevermind, the wastegate actuator rod had come loose
