2002 S60 2.4T, 86,000 miles
Only the driver side front door lock doesn't lock/unlock when using the key-less entry fob. Lock does work when manually keying. However, the driver side door DOES work key-lessly once every fifty fob hits or so. Two days ago the passenger side front door lock has started behaving in the same manner. My research tells me that the most likely fix is a new actuator. Fine with me, but now that a second door has become stricken I fear investing in a double actuator replacement only to find that the real problem lay somewhere else. Any trouble shooting ideas? Thanks
Keyless Entry Problem
Lucas Cheadle
- Year and Model: XC70 1999
- 1811 Views
Last post by Apesor
- 1722 Views
Last post by floodcity1
