How does it look like? Do I really need it? Because I noticed it's got a mention in the Volvospeed website, but I don't notice one when I have taken mine off, so I was wondering if that was the reason that my last bearing went bad?
How does it look like? Is there a part number? Should I put one back on?
Rubber Dust Shield between the axle shaft and hub bearing?
Kick Panel Broken Tabs Fix
- Year and Model: Many Volvos
- Been thanked: 76 times
I'm not real sure what you are asking about. The only rubber boot in that area is the boot on the CV joint and it is critical. You can replace the boot but it is often easier and more effective to just replace the axle if the boot is missing or torn and it has been for a while.
There is a metal dust shield behind the brake rotor that is in the vicinity of the hub and there is a plastic "gravel holder" on the top of the OEM control arms. I can't think of anything else in that area that could be called a dust shield.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Some volvos have a lipped seal ring that sticks on the outer CV joint and sort of seals the back side of hub bearing. can't recall seeing them on any P80.
I think it is a P2 piece but I do not think it is 100% on those either.
hi Ozark, thanks for the quick reply, I know the cv boot, that's what i've just replaced together with the hub bearing, I know what you mean by the gravel holder, which I've broke trying to get the control arm off the sub frame...
I also know the metal dust shield behind the rotor, which is not what I meant, so I'm not too sure either, but I've done some searching and even this post mentions it...
https://www.matthewsvolvosite.com/forums ... =1&t=30697
here is the volvospeed link it mentions it in the last paragraph...
http://volvospeed.com/volvo_repairs_how ... ement.html
hi jimmy: thanks for the reply also... your description does sounds like what I'm looking for...
hi there, anybody got any ideas regarding this rubber dust shield? It's not mentioned in the Haynes manual and I didn't see it when I dismantled the parts.... coz if it's not necessary, I can put the car back together again..
thanks in advance..
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
I have them on my 2000 XC. They are not critical, but are there for a reason. They prevent dirt and road grime from accumulating on the wheel speed sensors and in the hub area. The hub isn't in danger though, since it's a sealed unit. Honestly, not having them probably won't cause any issues... but personally I'd rather just have them on!
Easy way to put them back on without a total tear-apart:
-Remove wheel
-Remove axle bolt
-Remove top spindle bolt
-Loosen lower spindle bolt
-Remove 10mm ABS speed sensor
-Tilt spindle top towards you
-Push axle out of hub enough to slip on the rubber seal
-Put it back together, reverse!
I've gotten it down to a science now where I can take out an axle in about 15 minutes. It's quite easy!
Sent from my Droid using Tapatalk.
-Remove wheel
-Remove axle bolt
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
hi ecbsykes, thanks for the quick reply, problem i'm having right now is I can't find this rubber seal..
I guess I'll just leave it off for now, coz I can't find any part number or anything, couldn't be bothered travelling to volvo again to look for it.... thanks for all the help anyway...
FlyingVolvo
Well then I wouldn't worry about it. Volvo probably has it, although they'll likely charge some absurd price just for one. Not worth it!
2023 V60 T8 PE
2023 V60 T8 PE
rubber should be installed it keeps water from getting onto the axle splines this can allow axle ti seize to hub brg and future servicing could be costly one part num is 9492980 there is a vin split take your vin number to dealer
FlyingVolvo
PB Blaster + Hammervolvodoc wrote:rubber should be installed it keeps water from getting onto the axle splines this can allow axle ti seize to hub brg and future servicing could be costly one part num is 9492980 there is a vin split take your vin number to dealer
He does have a good point though. Checking it out on volvowholesaleparts.com they have that part for very little money.
2023 V60 T8 PE
2023 V60 T8 PE
- 1642 Views
- 1149 Views
Last post by 57gretsch
- 1629 Views
- 2463 Views
Last post by [email protected]
- 1017 Views
Last post by scdk
