Hi Everyone,
I have a 1994 850 and the third brake light is not working. It has in the past flickered on and off, but not recently. I have disassembled the housing already and cleaned all the contacts (one is broken but still makes contact) and replaced the bulb. None of this has fixed the problem. From reading a few other topics I can see that a lot of people recommend a new brake light switch. Would this be an appropriate fix for my issue? If not, what would be?
'94 850 Third Brake Light Issues
ItMeansIRoll
- Year and Model: 850 '94
Also, if it is the brake light switch, which of the two varieties should I use. My car is factory code two and the chassis number is is 1539** (I'm not really sure why I don't want to give out the last two digits, but I don't imagine they are important).
if the contact is broken, its not making good contact. see if you can solder it back together, or just replace the socket. your brake switch is fine as long as you have the other brake lights working.
93 850 GLT sedan 156K
94 850 Turbo 189K
94 850 Turbo 189K
toolmanjsp
- Year and Model: 1994 850
I had a lot of problem with the socket for the third brake light in the spoiler on the sedan. I would work then not work then work again. It even caused me to get pulled over one time when I probably shouldn't have been driving. Cop was kind though...
I soldered wires to a new bulb and to the leads in the trunk, stuffed it all in and called it good.
94 850 turbo sedan, teal (we call him "Dash")
95 850 turbo wagon, also teal! (we call her "Dash-ette")
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
There's only one switch for ALL the brake lights.ItMeansIRoll wrote:Hi Everyone,
If it's a wagon, you may have broken wire in the tailgate hinge.
Sedan? I'd put a meter on the wire feeding the third eye fixture.
ItMeansIRoll
The problem is the contacts within the light assembly, one of the two metal prongs has broken. I soldered a temporary replacement but it looks like I will have to replace that part at some point. I asked my local dealership about the part, apparently I have to purchase the whole assembly ($75). Does anyone know a better (read: cheaper) way to fix this? My solder won't last forever, there wasn't much metal left to work with.
Edit: My Volvo is a Sedan.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Cheaper!
http://www.fcpgroton.com/product-exec/p ... ght+Switch
Or do what I did - go pull one from a junkyard for $5!
'98 S70 T5
2016 Chevy Cruze Premier
- 13 Replies
- 5321 Views
Last post by S40volvo2007
- 1557 Views
Last post by Gdunk
- 1102 Views
- 4789 Views
Last post by ronkimes
- 7078 Views
Last post by Sommerfeldt
