I've got a million codes coming up on my car. My mechanic keeps working on it but it's still a mess. I'm trying to decided if I should just junk this car or if it's fixable..
First codes are the engine.... Ugh
Engine Coolant temperatue sensor 1 circuit high
Evaporative emission system pressure sensor/switch low
turbocharger/supercharger boost sensor a circuit high
turbocharger/supercharger boost sensor A circuit range/performance mass or volume air flow A circuit high
Intake air temperature sensor 1 circuit high
Now for the transmission..... BIGGER UGH!
Shift solenoid B performance/stuck off
Input/turbine speed sensor A circuit NO signal
Gear 4 incorrect ratio
transmission fluid pressure sensor/switch A air low
I just replaced the seal (?) somewhere on the tranny and within 300 miles it started leaking tranny fluid like crazy again..
ANY HELP HERE would be GREATLY appreciated!!!
