Remote responsiveness
537playing
- Year and Model: 2005 S60
- Has thanked: 1 time
- Been thanked: 5 times
My 2005 remote barely operates the door locks unless I continuously hit the buttons. Right away I replaced the battery but getting the same unresponsiveness. Is it the remote or the receiving unit within the car?
jimmy57
- Been thanked: 320 times
the receiver is the inside rear view mirror. Is there anything around the mirror that might block reception?
The other thing that comes to mind is the touch area on circuit board needing to be cleaned. what car is it? You only call it a 2005
537playing
2005 S60 2.5T
No obstructions.
You mention a circuit board to clean. Is this by the rearview mirror ?
No obstructions.
jimmy57
No I mean in the remote. TV remotes and car remotes both use the rubber button membrane with carbon rich spots to close the circuit between two elements on a PC board. The carbon spot can get rubber bleed and the PC board can get oxidized. Then you have to mash and wiggle to get the remote to work. You take it apart and wash the rubber membrane and use a pencil eraser on the spots on PC board.
537playing
Thanks for advice, but that didn't work for this remote.e
537playing
Another observation- I need to push the remote's buttons three times before the car responds! WTH?
537playing
Today the remote works excellent only after running my ViDA on the car. What triggered the improvement is unknown to me. Perhaps just a resetting of the electronics was the solution.
JRL
- Year and Model: Several
- Been thanked: 16 times
If you can't fix it you need a new remote
537playing
It's fixed.
