850 Heater core replacement
This topic is in the MVS Volvo Repair Database » Heater Core Replacement on the 850
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
FCP Groton often have specials for 850 heater cores (sometimes as little as $70 on eBay)
If you have a small heater core breach, the smell can be overpowering through the vents.
Heater core replacement on the 850 is not a difficult procedure. Once the kickpanels are removed there are four torx screws and some clips at the heater pipe coupling inside the vehicle. Some upside down work in confined spaces with the blood rushing to your head is sure to happen :roll:
The tricky bit is resealing your heater pipes using an old firewall coupling. This is best replaced with a new component.
Some wet & dry sandpaper or fine grade steel wool will come in handy to clean the heater pipe ends, especially if they are made of iron (Volvo switched to aluminium mid 95 to avoid corrosion)
List of parts for a foolproof change:
1) New heater core (OEM part number 9144221)
2) New firewall coupling (OEM part number 3522035)
3) New heater hoses (part numbers vary depending on whether it's a turbo or not)
4) Some old towels to catch the coolant as it escapes from the core
5) Some petroleum jelly for assisting the removal of the hose coupling (to be smeared on the rubberised flooring and hose coupling for easy pipe entry)
Don't bother with the URO seal kit. It only includes the heater hose side seal kit, not the heater pipe side and old seal components can remain lodged in the coupling.
I tried the URO seal kit with a coupling that had been removed and internally checked for notches and burrs only to be disappointed by massive leaks. I have taken some photos of the recent install on my wagon which went really well. Hope I'm not jumping the gun here, but it seemed a good opportunity to post these while they were fresh in my mind.
As far as procedure with heater hoses and heater pipes I smeared just a little petroleum jelly on the engine and heater pipe side of the coupling. This greatly assists a smooth entry of all the pipes.
taxidad
Year and Model: V70 XC 1999
Post by taxidad »
Hi Matt, I was wondering if you are going to post those photos. There was a link on another thread, with a photographic procedure a few months ago, but the link doesn't work anymore https://www.matthewsvolvosite.com/forums ... =1&t=36218 Would be great to have yours up for my upcoming procedure :-) Thanks.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Type in "heater core 2" to the search box and you'll find the write up with pictures :)
'98 S70 T5
2016 Chevy Cruze Premier
taxidad
Post by taxidad »
Brilliant, got it - thanks :-)
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
What am I missing here? I typed in "heater core 2" both with and without the quotes and it just brings me to the original article, no pictures.
taxidad
Post by taxidad »
Try this link https://www.matthewsvolvosite.com/forums ... hp?t=40547
Otherwise there's two search boxes on the page. Don't use the one next to 'post reply'. There's another up to the right just above the amazon bar. It has 'google custom search' faintly written. type it in there & then select "Volvo 850 replacement core 2". You should get the article with pictures.
shakamambutu
Year and Model: 1994 volvo 850 2.4
Post by shakamambutu »
hi matt i heard that you can change the heater core from nside the car ffrom under the passenger side dash or something like that... is that correct and if not then what is the way that i can do it from inside?
also i have a hole in my exhaust pipe (if thats what its called ( i mean the pipe after the catalytic convertor) and now the car is very loud. i heard there is some type of metal or aluminium tape which can be used to tape around that pipe, is that true? also what other solution is there just to cover up a small hole?
tjts1
Year and Model: 96 855 NA 5 speed
Been thanked: 4 times
Post by tjts1 »
shakamambutu wrote:hi matt i heard that you can change the heater core from nside the car ffrom under the passenger side dash or something like that... is that correct and if not then what is the way that i can do it from inside?
Here's a good writeup that should help you.
https://www.matthewsvolvosite.com/forums ... =1&t=40547
Ambitious but rubbish
