Engine rattles after turning off. 1999 S70
arrowrod
Year and Model: s70 1999
Post by arrowrod »
I get a rattle in the engine compartment, when I turn off the ignition.
I have seen some complaints about motor mounts needed to be replaced. My S70 has 142K miles.
Anybody with this experience?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Either your lower (front) engine mount by the crank pulley or the torque rod bushing up top that connects it to the firewall.
'98 S70 T5
2016 Chevy Cruze Premier
IVIUSTANG
Year and Model: 2006 XC70
Been thanked: 4 times
Post by IVIUSTANG »
jblackburn wrote:Either your lower (front) engine mount by the crank pulley or the torque rod bushing up top that connects it to the firewall.
This answer is a winner!!! More than likely the front engine mount, mine was so bad it was missing and the engine was resting on the subframe :lol:
- Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires :D
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
Juan62
Year and Model: S70 T-5M 1998
Been thanked: 2 times
Post by Juan62 »
Mine does that too... (98 S70 T5-M). How can I properly dianose this issue? I look under the front right tire, remove the two 10mm bolts from the inner wheel well, identified the engine mount, and it (appears) to be okay. I have the new IPD HD upper engine mount installed. Is there something else I'm missing? Thanks.
98 S70 T5-M Brick for life
arrowrod
Post by arrowrod »
Replaced the "front" motor mount. (The one next to the passenger side front tire.)
I swear, the car runs smoother. Turning off the engine still shakes slightly, but the "rattle" seems to be eliminated. The old mount was intact, but I think the rubber was "stretchier" (Where did I go to school?).
As I work my way around the car, it appears that a California car fares better after 140K miles than non-California cars.
The front end bushings are tight, there is no wiggle that I can detect. No rust on the undercarriage. If I didn't get tired of a car after 12 to 15 years, I might keep it.
Do 5 cylinder cars all shake when turned off?
jblackburn
Mine shakes a little bit when i switch the key off FWIW.
'98 S70 T5
