I've been on a few sites but there are only 2 posts everyother day. I don;t have alot of time. There is no site that I know of that is as active as this one. Therefore I wanted to take my question here in hope that someone will have the answer. If anyone feels the question inappropriate for the forum, I stand corrected. Just remove the post. Here goes, I have a question on a 1993 1200 sportster, symptoms: Will not start without a jump, eratic tachometer, and tach advances when hand brake in pressed, no blinkers.
Battery is shot, tried a fully charged battery, didn't start, bike running/alt 10 volts
Battery, Alternator, reulator, anyone?
I start 10 days off work tomorrow and I may go insane with a broken bike.
Motorcycle question
aahmes57
Motorcycle question
1991 740 (saved a life)
1998 S70 Turbo caught fire, very sad day
1995 850 sold
1999 V70 Base daily driver
1995 850 sold
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 73 times
I don't know much about motorcycles, but something definitely sounds screwy with the electrical system. As was suggested, maybe replace the voltage regulator?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
aahmes57
Thanks matt4nu but it isn't the regulator. I thought the same. What has me puzzled is the no blinkers with the eratic tach.
Still troubleshooting
Thanks
Thanks
1995 850 sold
1995 850 sold
aahmes57
Thank you gentlemen and or ladies. I started tracing the wires last night. I'm beginning to think I may have more then one issue, they just happened at the same time.
With any luck I should be up and running this weekend. It's a shame when the bike goes down, everything else gets put on the back burner and spouse's aren't very happy.
Thanks all for your imput.
1995 850 sold
1995 850 sold
elchopperfreak
- Year and Model: S70 T5 1999
For what its worth and its been some time from your post, do you hace the original headlight on the bike? I would check inside the headlight buckets, most of the wiring is there, also, it could be that the handlebar switches, they have a small slot that allows the wiring to go through, sometimes the switch housing "bite" the wires and screws the system.
You will know if your regulator or charging system is shot by revving aprox to 2 thousand rpm and with a volt meter check the charge in the batt wires, normally when the regulator is gone, the bike dies after a bit, or your headlight bulb blows up.
Im pretty sure its the wiring.. Also check that sometimes by turning the wheel, the wires that run down might get pinched..
