variable valve timing
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
dale
Year and Model: v70glt 1998
Post by dale »
How does the variable valve timing work on the 2008 3.2 S 80 What adjusts it and how is it adjusted in the engine?
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The 3.2 has intake cam variable valve timing and 2 level intake vale opening.
Below around 3000 rpm the intake valves are only lifted off seat 3.6 mm and throttle opening and cam timing control engine speed.
Above that rpm the valve opening is 10mm and throttle is the engine speed control with some cam timing changes primarily for improved torque and lowered emissions.
The intake is also 3 stage design with two dampers to alter plenum+runner volumes for optimal pressure wave tuning.
The intake cam has a hub with radial vanes working inside pie slice shaped chambers. Oil pressure control in the chamber split in two by the radial vanes controls where the cam is in its travel range. The ECM controls an on-off pulse to the oil control valve. The valve sends oil to one side of vane when not powered and to the other side of vane when powered.
The cam position sensor is monitored relative to crankshaft position in order for ECM to know what signal will get cam to desired position.
