Temperature Sensor in drivers side miror
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
Susan
Year and Model: S40 2006
Post by Susan »
The dashboard display for ambient temperature does not work in my 2006 S40. After checking forums I seem to need a new senor or at the least to check for corrosion of the old one. Can anyone tell me how to disassemble the part under the mirror or if I need a certified mechanic to do this job?
P.S. Last week my seat belt was stuck in its place. Is this a related problem in the electronic system?
Thanks,
Susan
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The temp sensor issue is well known to volvo techs. The connector at door to body harness needs to be repaired or replaced. The pins corrode.
The seatbelt would be unrelated
Susan
Post by Susan »
Thank you.
