850 exhaust
850 exhaust
I have a '93 that has a boken exhaust pipe. I have a '93 for parts. How do I change exhaust pipe. In peticular, how do I remove the sensor withe the wire that goes to pipe below the maniforld.?
97 GLT
The sensor I believe you are talking about is the oxygen sensor (front) and requires a special socket to remove it due to limited space.
- Has thanked: 2656 times
- Been thanked: 1248 times
Front o2 sensor does not need anything special to remove it, save for a 19mm or so open-end wrench. IPD sells a fancy tool to do it, but then again, that's their job.
I did my front o2 sensor and the hardest part is un/doing the wiring harness, believe it or not. Remember to hit the sensor with some WD-40 or equivalent because it will be really tight.
