emission issues.po172 left
curtismc56
Year and Model: S70 1998
Post by curtismc56 »
98 s70 100k+. Replaced the MAF twice, Front O2 sensor now the only one left is PO172. Sprayed ether gently around vacum lines, no increase in rpm's. Where do I go from here.
curtismc56
As jblackburn suggested, I replaced the elbow coming off the vacuum mod. Replaced the 2" intake to exhaust tube. Whats next?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Is that same elbow connected at the other end? Any leaks coming off the bottom of lines connected to the intake manifold? Fuel pressure regulator?
Is this a turbo motor or non-turbo? If it's a non-turbo, the FPR is near the fuel tank on the right side of the car.
'98 S70 T5
2016 Chevy Cruze Premier
gilhuly
Year and Model: 98 V70 GLT
Post by gilhuly »
If you're not hell bent on doing it the hard way go to an idy garage with a smoke machine. You'll have your answer in 15 mins.
1998 V70 GLT, 15G swap
Fairfield, CT
