960 Electrical Failure Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
960Rich
Post by 960Rich »
Hi,
I went to test drive a 59,000 mile '96 960 yesterday. The following components didn't work: headlights, brakelights, moonroof, windows, shifter. We didn't test drive the vehicle. When I called back to the salesperson about 30 minutes later, he said he went to drive the car to the mechanic and said all componets were working....any ideas as to what may be causing this...could there be some type of intermittent electronic control module? Any idea of potential costs...I would like to own the vehicle but be financially and mentally prepared for a future repair if this happens again...
(fyi, it was raining...moisture issues?)
Thanks!
960 Rich
Post by 960 Rich »
Hi,
Apparently, the problem was a short in the ignition switch assembly.
With slight movement of the stering column the problem would appear/dissapear.
The brake lights were a separate problem.
Rich
petershen1984
Post by petershen1984 »
exactly right, the brake lights should light up when depressed regardless of key position. Sometimes a short in my ignition switch acts as though it sticks in the starting position - the car has started the key returned to ON position, but power accessories stay in disabled mode. It works again next restart :-)
Peter Shen
1992 Volvo 960 (Silver)
