CEM-1C01 L-signal Signal too high (vida dice)
How to buy, install and use VIDA, VADIS, DiCE, VMWare and all the questions and answers that come with these tools.
carboncow
Year and Model: 2003 XC70 2018 S60
Post by carboncow »
While troubleshooting what I suspect is a bad alternator in our 2001 V70 T5 I was looking at all the errors in the Vida DiCE CSC. For for the CEM is as mentioned in the subject and says "signal too high".
Does anyone know what this pertains to and if low voltage from a bad voltage regulator can (and how) cause this?
8-16-2011 9-40-26 PM.png.jpg (41.24 KiB) Viewed 6157 times
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
1999 Porsche Boxster
2004 Chevy Suburban LT 5.3L
2013 & 2015 S60 T5
2008 Vw Touareg T2 V6
1989 Sea Ray 340 Sundander
2007 Sea Doo Challenger 180 SE
jimmy57
Been thanked: 320 times
Post by jimmy57 »
1st code: maybe bad connection to the sensor on the CCM panel or can be low battery voltage related.
2nd code: low battery voltage clear and check later to see if it returns
3rd code: low battery voltage
4th code: Loose or missing bulb in rear
I would clear codes and not worry about any of those.
Did the key get left on long enough for the message display to show "low battery voltage"?
carboncow
Post by carboncow »
Thanks Jimmy...wasn't sure if the 2nd code was related to the low voltage of the bad alternator and/or voltage regulator since it was saying "signal to high".
That first one has always been there and never bothered to get another fan/sensor so I will check the connection as someone may have been in there before.
Shawn F.
2001 V70 T5
2003 XC70
1996 Vw Passat Tdi
2013 & 2015 S60 T5
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
An old thread, but found it relevant today.
I'll clear and check again. Meanwhile, why a long list of Checking...?
