1990 740 Turbo Idle setting
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
n1cjs
Year and Model: 740, 1990
Post by n1cjs »
I'm new to this group and this is my first question, so bear with me...
I have a (new to me) 1990 740 Turbo wagon that seems to have a very low idle. It shows about 600-700 on the tach. I have done a search (the best I could) to try and find out what the correct idle speed should be. What is the correct idle and how do you adjust it if need be??
Thanks, Chris
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
The idle speed for the turbo should be about 750rpm. Idle problems on these cars are often down to a dirty throttle body.
To clean the throttle body you need to remove it, spray it with a fuel injection cleaner, not a carburettor cleaner, and brush off any stubborn deposits with an old tooth brush. Refit with a new paper gasket, inexpensive even from a Volvo dealer, and see if it makes a difference.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
n1cjs
Post by n1cjs »
Thanks Bill. I'm picking up a can and gasket this weekend and going to start there.
Chris
kingsorder
Year and Model: 1990 740 turbo
Post by kingsorder »
i have the same car , just wondering if this solvo your problem ?
n1cjs
Post by n1cjs »
UPDATE!
I did not have time this weekend to do the fuel inj. cleaner cleaning job, but did however (i think) fixed the low idle I thought I was having.
This morning on my drive to work, I heard something under the car making a slapping noise. Ended up being a loose plastic shield. Got that tied up and alls well there. So while I was tinkering around, I thought I would look at the throtle body and see just what I'm in for. Well low and behold, there is a little screw on the front tward the bottom that looks like it has something to do with the throtle linkage. Well after freeing up the jam nut and about a half turn of the screw the idle went right up to about 750 and sounded much better.
What started this whole question for me is when I was at a light last week, the clutch fan kicked in and just about killed the engine. Now with the idle up a bit, where it should be, it will be interesting to see what happens when the fan kicks in next time.
I'll keep you posted.....
Thanks
