'98 V70R - Leaking Turbo Coolant Return Pipe
scoobycant
- Year and Model: '98 V70 R
My turbo coolant return pipe was leaking. The weld between the pipe and the mounting tab had corroded and cracked. New pipe is on order. I cut out the bad section of pipe with a Dremel tool, and clamped in a 5" long section of 3/8" ID, fuel injection hose. Went for a test drive, returned, turned off engine, and checked for leaks. Temporary repair was ok. Problem is that I'll be driving vehicle about 750 miles before I can install the new tube next weekend. Wondering if the fuel injection hose will hold up until then. Really, really, really don't want to risk overheating due to coolant loss. Am I asking for trouble here?
'98 V70 R (Saffron) 208k
'99 V70 XC (Silver) Sold
'99 S80 T6 (Blue) Sold
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
I'd think that if the hose can handle ~300F then you'll be OK. If you don't know, I'd take a piece of it and stick it in your oven for an hour.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
- 2939 Views
Last post by bmdubya1198
- 1912 Views
Last post by rmurphy7
- 306 Views
Last post by Scruffy
- 477 Views
Last post by FLXC90
- 5130 Views
Last post by darrylrobert
