Thankx
Exterior trim
Exterior trim
Someone with body experience? Is there a trick to safely removing exterior trim pieces
Thankx
Thankx
Git Er Done
dbeckwith
264,000 miles
dbeckwith
264,000 miles
which trim? the door bump guards?
There is a clip at the rear of the trim that you have to pop the trim off of(using a plastic stick or pry tool), and then the whole piece will slide to the rear of the car @ an inch. You can them pull the trim off away from the car, and you will see the slots where the moulding clips slide into. The fender trim just pops off the body, and the clips stay on the panel.
93 850 GLT sedan 156K
94 850 Turbo 189K
94 850 Turbo 189K
Thank you phat78ta! The original trim has become quite faded and I thought I would spruce it up a bit. Much easier to take it off than trying to mask it and hope you don't get any runs
Git Er Done
dbeckwith
264,000 miles
dbeckwith
264,000 miles
benrice33
- Year and Model: 855 GLT manual, 1995
If you haven't already started your respray job there is a thread about how to use a heat gun to recondition the plastic and darken them up some. Here's the link: https://www.matthewsvolvosite.com/forums/viewtopic.php?f=29&t=38239&p=181469
'95 850 GLT w/ 5spd, throttle body and airbox mod
benrice33 wrote:If you haven't already started your respray job there is a thread about how to use a heat gun to recondition the plastic and darken them up some. Here's the link: https://www.matthewsvolvosite.com/forums/viewtopic.php?f=29&t=38239&p=181469
Now that you bring it up I remember the post about the heat gun. Alas, I had already started on the door trim with Forever Black. I had purchased this stuff months ago so I thought if I could get the trim off and do it inside instead of in the heat outside I would give it a shot. So far not entirely impressed, although it is noticeably darker when placed side by side with an untreated piece. Now if I can figure out how to remove bumper pieces without messing them up I can do those inside also. That will result in a remarkable difference
Git Er Done
dbeckwith
264,000 miles
dbeckwith
264,000 miles
- Has thanked: 292 times
- Been thanked: 765 times
Just wanted to save some others a headache: this was the most detailed post I could find for removing the exterior door trim (bump guards), but the instructions here are wrong. I mean perhaps this method works, but it will bend and damage the trim. Not surprisingly, Volvo designed a much cleaner way to get it done.phat78ta wrote:which trim? the door bump guards?
The trim is held on by 4 or 5 clips. The key to the removal is this: the rear-most clip is held on by a T-15 screw, while the other clips each slide into a notch in the door shell. So to remove the trim, open the door, locate the round plastic plug that hides the rear-most screw, back by the door latch. Pop off the little black cap then unscrew and remove the 1/4 inch long screw behind it (uses a T-15 torx). Now, with the door open, slide the trim piece *forward* (NOT backward as described above!!). The sliding will release the other clips from their notches. The trim piece will just fall off in your hands, with all the clips intact and still attached. No forcing, no banging, piece of cake, takes like 2 minutes. Installation is the reverse.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
LOL, when I seen those instructions above, I said, Oh No!!! The removal should take less than 2 minutes but I guess the point is made. The door has slots and groves in it made to channel the door clips. Just a little note, that T-15 screw likes to fall down in the door so try not to drop it.
The front finder molding does slide and pull off, I'll double check it and post back in a few minutes.
- 778 Views
Last post by Volvo S80
- 620 Views
Last post by bmdubya1198
