960 reluctant to rev over 3000 rpm
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
tomatoes4all
Year and Model: XC70 D5 MY2010
Post by tomatoes4all »
Hi all,
My 1992 960 with 1995 engine, 250,000 km/155,000 miles has some minor issues that I can not seem to fix.
Running rich, poor milage( poorer than usual I should say) on lpg as well as petrol. A poor idle and reluctance to rev over 3000 rpm started while on lpg, so I had the lpg system adjusted. The technician was unable to get all 6 injectors to "balance" properly, because the engine would not run perfectly on petrol either. I have looked over his shoulder while adjusting the injectors and the engine management system and indeed, not running well. He suggested to replace the MAF, as it was dying. The goal is now to get it perfect while running on petrol and then go back to get the lpg system running well.
I have checked the old MAF (thank you Bill!) and purchased another one, which checked out OK, 3.2 Ohms. engine idles very nicely with the "new"MAF, very clean air inlet, air filter is clean, no vacuum leaks as far as I can tell. Sparkplugs are only 5 months old. My car idles well, but hesitates slightly when accelerating from a stop, uses too much petrol compared to a few weeks ago, but does not want to rev higher than 3000 rpm, unless I really put the boot in so to speak. When accelerating firmly the car sometimes "hangs up", i.e. does not shift up into a higher gear and does not want to rev any faster either. The front grill of the Kenworth gets closer and closer as I try to merge onto the freeway.... Where is that 204 hp from a few months ago? Can anyone shine a light on this problem for me?
Thank you, best regards, Erik.
precopster
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Hi Erik, sounds like it's time for a compression check. Are you losing coolant?
Do this with a warm engine first, then squirt some oil in and see if compression rises. You should get over 190psi.
Because the engine runs badly on both LPG and fuel I'm not going to suggest checking fuel pressures. Another possibility is failing coil packs.
If oil fails to raise the compression you may have a badly seated valve(s)
Have you moved to Sydney yet?
Alpha Bill
Year and Model: 960, 1997
Post by Alpha Bill »
You did not state whether your car has the Aisin automatic transmission. If it does, your current problem could be with the transmission, not the engine. I took my 1997 960 to the best transmission mechanic I know and now the car revs right up to 6000 rpm; and down shifts "right now" upon pedal depression. Also, if your transmission has the "Winter", Economy" & "Speed" buttons, those might not be operating properly.
Alpha Bill
jimmy57
Been thanked: 320 times
Post by jimmy57 »
Has anyone checked for the catalytic converter being stopped up? If no catalyst is fitted to that year AUS models then muffler or front pipe blockage.
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
have you checked the fuel pressure ??
1996 Platinum Edition
tomatoes4all
Thanks all for your hints. I will get the transmission checked by a transmission mechanic, but fluid level is good and fluid is clean, nice and red. Catalytic converter was changed about a month ago with a used unit, which was checked before installation. I would check fuel pressure if I would know how to do this. Could you tell me how to, please?
Precopster: I will also do a compression check, after removing all the lpg injectors, they are right on top of the inlet manifold and the valve cover, looks like a better part of the day. I have a single meter, as in one cylinder at a time. From some of the instructions on this site I get the impression that most measure all cylinders at once?
I have moved for work to the central coast, about 90 minutes north of Sydney, but fly back to Adelaide every 2 weeks for 3 days to see my bride and children. We will all move here early october; till that time I have extra time to get my car back in good shape.. Best regards, Erik.
tomatoes4all
Hi all, just an update. The culprit was a faulty ignition module! Had this replaced at the Volvo specialist, as I was by now taking random stabs at this problem. Took them 20 minutes to diagnose and the same time to replace. Took the car home today and all is good now, smooth and strong acceleration, will red line when asked and transmission shift smooth as well! Love driving "Thomas the tank" again!
Thanks for all your suggestions and help, dear Volvo community!! Best regards, Erik.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Thank you for the update.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
dcarlson12
Year and Model: 1997 850 T5
Been thanked: 2 times
Post by dcarlson12 »
Erik,
Just interested to know how they diagnosed the faulty ignition module? Did they use special equipment or ???
tomatoes4all
Hi dcarlson12,
I understand they used the process of elimination, ended up with the ignition module, removed it, tested it and came up with "dead" readings. I am happy the problem is fixed now, it just got too dangerous to merge on the motorway or even crossing an intersection. I never knew if I would get acceleration or not.
By the way: Surrey, BC? I lived in Maple Ridge and Pitt Meadows for 10 years. Small world, eh?
Best regards, Erik.
