install mbc on 95 850 T
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
Darmo
Post by Darmo »
So, On my 95 850 turbo, There is a hose from the wastegate actuator, one from the turbo, and one from after the mass air sensor going to a solenoid or sensor. How should i connect my mbc in here.
adrianpike
Post by adrianpike »
Connect it inline with the wastegate actuator.
Ensure that you've got enough additional fuel as you up the boost.
Watch exhaust gas temps and/or AFR's so you don't detonate it to death.
-Adrian Pike, Adrian Technologies
'78 16 Valve 245DL
