I lose power, please help.
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
John_f
Post by John_f »
Hi,
I have a problem with my 2000 T6, I lose power all the time !!! (the battery is new, and it is a good quality)
In the past, I had the problem that the small "fan" for the A/C unit, in the dashboard, was turning all the time. That small fan is now discounected.
And sometimes after approx ½ hour, after I lock the car, the A/C fan is runnig on full power, until I start the car again, and shut it down again.
What is my problem??
Cheers,
John
MNM
Year and Model: S80,2000
Post by MNM »
The fan on the AC unit can sometimes come on to clear condensation in the system when the AC is used. This should only last a few minutes Nd it's a normal thing with volvox. If however this is draining your battery then something else is working along side the AC. Check to see if you have left nothing on or get an auto electrician to check your charging system. Hope this helps
